Tint on drivers door getting scratched
I had to take off my door panel when I put on my jdm thin moldings. This was the first time I’ve taken off the drivers door. Anyway, now there are thin scratches on the inside tint like from the points on a screw. The one closest to the front of the car is most likely from the door handle screw so I will take car of that. The other scratch is like 2 inches back. Any ideas on which screw that would be? I’m gonna take it apart here soon but was just trying to get some ideas?
:gotpics: i want to see these thin moldings, and where did you buy them?
They typically cost $160. A guy I know was selling his DA and he got these when he bought the car. I low balled him $60, and he took it. I don’t have any pics but they sell them at passwordjdm.com.
http://passwordjdm.com/JDM-DA-90-93-Integra-Thin-Side-Moldings-Coupe-P1017C77.aspx
check the guides for your window. there are tracks in the door that the window slides up and down on, if you bumped one of those out of alignment or got some junk in it it could be dragging on the tint. if thats the case, there are alignment screws toward the bottom of the tracks that you can use to adjust it, good luck.
Boy, that sounds like fun!!! I’ll give it a try.
I think I figured it out. I think the clips that hold the rubber trim at the base of the window I think were doing it. Well see…
