tire fitment
What size tires will fit on 15x6 rims?
problem w/ 15’s is that you have to choose between 195-55-15’s and 205-50-15’s. Both will fit just fine. the 195-55’s will be just a tad larger than stock and the 205-50’s will be a tad smaller than stock (talking about outer dia). So, which route you should take depends on your setup. If your car is slammed you should probably opt ofr the 195-55’s just so you don’t scrape even more than you already do.
and don’t think that automatically the 205-50’s will be a better tire because they are a lower profile…its all about specifics. I’m running 195-55-15 potenza re710’s on my car (well, actually i took them off cause they’re a bit worn) and they are AWESOME tires, just as low pro and just as wide as a good deal of 205-50’s out there. tire size only means so much, brand and how “performance” of a tire it is will dictate how wide, low profile, and grippy it actually is.
thanks:up:
im getting slipstreams tomorrow and it has tires already and its running 215/55/15 would it rub when mounted on my car?
