I’m not to sure if it’s called a tire hop or a clutch hop, but the majority of the time, when the car is cold, and starting out from 1st to 2nd, I let out the clutch and give the car some gas, like you obviously would be when you drive a standard, the car feels like it wants a match of Hop Scotch. Know what I mean? lol
Is this my clutch going or my flywheel needing to be machined again or do I need a traction bar for the car to stop the CONSTANT hopping. So.Effing.Annoying.
My car had a similar symptom when my motor mounts were shot. Did you check your motor mounts?
Actually no I never considered that. Got anything you could recomend?
that is not tire hop. tire hop is when you launch your car and your tires actually hop violently looking for traction. probably your clutch/flywheel like you mentioned. my old teg had the same problem and it was the clutch. 90% of the time it’s the clutch but like mentioned above check your engine mounts first. a bad engine mount will produce the same kind knocking feeling.
Oi… thinking maybe i’m going to have to rebuild the tranny before the suspension, err…
Ok so I think it won’t be SO bad after all. I got some options. A friend of mine can give his flywheel and get it machined for free through his work and I can buy a B series clutch for $50 from a friend who runs a shop here in Kelowna called, Four Function Autosport. Or I can I buy an Exedy clutch that’s basically an OEM replacement, same weight etc, just made by Exedy for $280+ taxes, or I can buy an ACT clutch for $390. Because I really want to save money and do my suspension I’m thinking, make the car functionable and driveable for the time and then drop the car by the end of the summer or winter. And do the motor mounts too while I’m at with some polyurathane bushing. shrugs Anybody else got some sugguestions?
