toe adjustment
Ok I have a question on the toe. It seem most say set it at zero is that zero for the front an back? as I know the front specs say -.08 to + .08 so zero in the front but the back if i recall says .00 to + .08 so would you still do it at zero or would it be say +.04? I should be going in next week to have it done again so any advice would be helpful on this.
Wait… why are you getting an alignment when you didn’t get your TA bushings replaced yet? I just did mine last week with that one guys X-tractor tool… it didn’t quite work since it’s the older model but I ghetto rigged it and it works fine.
If you’re planning to get your bushings replaced (RTA, LCA… etc…) then I suggest you do your alignment later after all those bushings replaced.
I hear you but I bought the tool an all my bushings are new front lower arms,new rear lca,trailing arm bushings,an the ones to do the toe in the back upper lower ball joints,an inner an outer tie rods (should be done this week tie rods) I just need to know were to set the rear toe.
As I think it should be set at .04 that would be the middle an the front at .00 that why I need to know were to set the rear so I can tell them when it goes in for it. I want to get my camber set right the toe set an I have adjustable radius rods from a accord for the caster so it can all be dialed in good
so should i do a .04 in the back? that will be the middle?
Set it zero front and back unless you’re looking to change handling characteristics. For instance, toe out in the rear can help the car rotate more easily - a characteristic which can be good for autoX. But if you’re not familiar w/ the settings or what you want (which sounds like this is the case), just set it to zero front and back, that will leave it as neutral as possible.
Personally I only know the basics about alignment and will usually search roadrace/autoX people’s specs to get an idea of what they’re doing to get various characteristics and then make some judgments based on that. But you also need to make sure that you realize they are probably better drivers than you so they can probably handle more extreme settings. This is why I will only use West End Alignment for my car, Darrin knows his stuff and is willing to spend a few minutes chatting about your setup, your car and what you want out of it in order to make the right decision on what settings to use.
Thanks for the info
have fun with the rear toe settings. the bolt that goes through the compensator arm tightens against a nut that rides on a rail inside the body. if it’s never been set, they will almost always be seized. which is a cunt because the only way to get at that nut is by cutting an access panel through the body.
sometimes you get lucky though…
[QUOTE=welfare;2132857]have fun with the rear toe settings. the bolt that goes through the compensator arm tightens against a nut that rides on a rail inside the body. if it’s never been set, they will almost always be seized. which is a cunt because the only way to get at that nut is by cutting an access panel through the body.
sometimes you get lucky though…[/QUOTE]
You’re in Canada, the cars there or anywhere it snows will more often have that problem. I’ve had a half dozen da’s and haven’t had that problem. Similar problem happened to a friend on a da he had from Canada though.
mine are mint still. probably the only one in quebec.
guess I got lucky too when I changed my RTA’s…not so lucky with all of my LCA’s and Spindle Nuts. Daaaaam those were a bitch.
oh yea. forgot about that detail
BC doesn’t use salt though, do they? Ontario does and my car most certainly pays for it :frowning:
You are in Cali, where it doesn’t snow/rain as much. Anywhere it rains, suspension bolts on older cars like to seize up. I see it every now and then at work with stuff that is pre-1997. Happens but oh well.
this got so off topic lol
Thats exactly what I stated. Dariousone is in cali, so the OP’s comment didn’t really have a place in this thread…
Welcome to the new and improved G2ic… Where everyone feels that any comment is valid in any thread.
