Hey, I’m asking you cause you’ve done some similar work.
I’ve already checked the search but didn’t get what i wanted. I’ve got a 92, would i be right in saying that if i were to take off my front “A” emblem that there would be two little pin holes???
Re: Tony??
yup. that’s the only reason those nasty red emblems are on my hood right now after i got a new hood. you have to get them shaved (closed up) if you don’t want emblems.
That sucks! I wanta shave my “A” and my stock antenna, but i’m affraid of doning all the bondo and paint. The shaving wouldn’t be too bad but i can see myself screwing up the paint.
That sucks! I wanta shave my “A” and my stock antenna, but i’m affraid of doning all the bondo and paint.The shaving wouldn’t be too bad but i can see myself screwing up the paint.
shaving your emblems is not something i would advise you doing yourself. for the antenna… you can’t just use bondo… cause there is nothing for it to rest on and would sink in eventually… you’ll probably want to get it welded shut. and since there’s no good stopping point… you would have to repaint your hood and that rear driver’s side panel after you shave it. it’s not cheap. HTH
