Too much clutch lever play? B20b + LS ys1.
Ok…I have a '91 Integra that I’m swapping a '96 b20b and '92 ys1 in to. Before I got the ys1, I thought I was just going to re-use my trans so I ordered the 90-91 Exedy OEM clutch kit. I then got the ys1, and had to order a new 92-93 Exedy clutch disc and alignment tool due to the small/large spline difference. I still used the pressure plate, pilot bearing and release bearing from the 90-91 kit since they’re the same for all 90-93 and because I didn’t want to order a whole new 92-93 kit. I also ordered a brand-new fork spring from Honda. Greased everything I was supposed to grease, had my '91 b18a1 flywheel resurfaced a total of .010", everything installed nicely.
Anyways, I got everything installed and got the trans bolted up to the motor…both are OUT of the car…I realized the clutch lever has quite a bit of up travel to it. When I pull up on it, that release bearing feels like it’s traveling down that release bearing tube pretty far before the lever stops going up. I’d say maybe 2-3" of pulling up on that lever before it stops, which seems more than I remember it doing on my original running gear. It takes no force at all to pull that lever, can lift it with my pinky.
Should the lever be able to move that far up before stopping at what I’m assuming are the fingers on the pressure plate? If this isn’t normal, what could be wrong? I’m afraid to drop this new gear in my car not knowing if I have to pull the trans back off the motor and fix/replace something.
I ran into the same thing when i did my auto to manual swap. Everybody that looked at it said that something was wrong and i needed to pull it apart. Well i was confident that i put everything back correctly and sure enough it worked. I could move that lever alot and you could hear the throwout bearing hitting the pressure plate.
So you left it, and it ended up being fine?
you might have a big problem.
From what i’ve heard, the 90-91 clutch has a different center diameter than a 92-93 clutch. You might want to order the 92-93 clutch disc instead.
If i’m completely wrong, have you tried to adjust the clutch cable yet?
90-91 trans = small spline.
92+ trans = large spline.
I ordered the 90-91 Exedy OEM clutch kit, thinking I was going to re-use my trans out of my car since it’s a 91. I ended up getting a rebuilt ys1, so I had to order a new clutch disc and alignment tool meant for the large spline 92+ transmissions. If I installed the small spline clutch disc, I wouldn’t have even been able to install that ys1 trans because the shaft on it is large spline. I did use the pressure plate, pilot bearing and release bearing from the 90-91 kit instead of ordering a whole new kit. The flywheel is the one that came off my '91 b18a1, just resurfaced about .010".
The motor and trans are together, out of the car. I didn’t want to swap them in yet, because I thought maybe the clutch lever play was too much and might lead to having to remove the trans.
opps sorry about that, totally missed the part where you said you changed the disc also.
Yeah, I’m good on all the parts, the install went flawlessly. I’m just trying to figure out if that’s too much play, or normal. I really don’t want to finish the swap and find out the hard way that something isn’t right.
Yes sir.
If I got this correct…
When you hit the clutch pedal, it moves the release bearing against the pressure plate fingers and presses on them, relieving the pressure plate’s f5riction surface from the clutch. The more material the clutch has, the closer those fingers are to the motor. The less material the clutch has, the closer those fingers are to the trans. This would mean my old running gear, with my old and very worn out clutch, had the pressure plate fingers extending closer to the trans meaning less up travel in the clutch lever…and vice versa with this all new setup.
Is this about right, and would it explain the fact the lever has more play than my old setup?
correct, shouldn’t be much of a difference. But yea the fingers are closer to the engine on a new clutch. Your clutch fingers should be pretty flat if you torqued down the pressure plate correctly.
I checked the lever again today, and I guess it’s not 2-3"…more like 1-1.5", so maybe that is normal. Went ahead and dropped the motor/trans in. Tomorrow I’m going to hook everything up and take her for a spin, as long as nothing goes wrong.
i just replaced my clutch last week. 1" - 1.5" is about the amount i had in mine.
i believe you need play for when your foot is to rest on the clutch pedal it doesn’t wear the throw out bearing faster.
if the clutch cable isn’t connected it’s normal for the release arm to move a couple inches. once you connect the clutch cable and adjust the freeplay everything will be alright.
