The clutch disc has to match the input splines of the transmission. Your S1 has a small spline like A1 & Y1 transmissions. B series transmissions from 92 on use a larger spline. Just pull the disc and see if it fits on the input shaft of your S1 transmission.
I personally would never install a used clutch. It’s worth the money to buy new while you have it apart.
