I was putting in new intake today and when I put the battery in I touched it to the wrong side and it sparked and left a small hole in the battery terminal. now the car has no power at all. what do i need to do to get it started?
Check all your fuses.
Make sure the battery is still working. You may need to take to a shop and have them test it if you don’t have a volt meter.
Your main 40 amp fuse in the under hood fuse box is blown. Replace it and everything will work fine.
Actually it was the 80 amp. I replaced it with a 70 for now, autozone didn’t have an 80 in stock (at least not with the bent out legs).
Thanks for the help.
