So as i was going to sleep to go to work in the morning i woke up to find my car was side swiped and fucked my whole left side. Thanks a lot drunk drivers. I was wondering if anyone had some extra parts i need a rear bumper, a left fender and maybe another set of side markers. well further a do here a some pics
scuffed the fuck out of my rim
and i got to figure out how to fix my rear quarter panel
yea man that sux! have fun fixing the dent in the quarter panel where it curves under the tail light, thats gonna be ur biggest challenge and u have to get so many curves back to perfect…good luck fixing her back up
if the rear wheel is bent the entire subframe could be bent beyond repair… same thing happened to my accord.
I See you are local. I know a good shop in the campbell area.
Sadly the 2 biggest threats tto a DA out here are theives and drunks… I do have a driver side front mudflap in the event yours is trashed I can donate.
either the above post or a maybe just a trailing arm…you might have more than just ‘visible’ damage…get on the search for a replacement car just in case
Well glad to know that you are safe and this dident happen while you were driving on the road. However, best of luck to you and your DA. If you manage to overcome this tragedy it would be one hell of a comeback.
[QUOTE=djzachtyler;2275663]if the rear wheel is bent the entire subframe could be bent beyond repair… same thing happened to my accord.
Sadly the 2 biggest threats tto a DA out here are theives and drunks… I do have a driver side front mudflap in the event yours is trashed I can donate.[/QUOTE]
I hope that isnt the case, whats the place in Campbell?
looks repairable from what i can see, for the rear under the tail light gotta remove the interior panels and you can get a body hammer and dolly in there, replace the fender and probably just bodywork the door… i’d say to see if an alignment shop can just check the alignment and see if there’s a big difference in camber angles as well as more than adjustable toe angle and go from there… i just recently finished my DB2 after getting t-boned and yours looks like you can save it…
good guy Came highly recommended by my mechanic. I’ll be having him repair all the stupid screw holes form the aftermarket skirts the last owner had attached to my teg. he quoted me 500 to sand and tack weld the holes, flush up the bottom front sides behind the fenders where idjits jacked the car up incorrectly and primer all the work.
I liked that he prefers welds to just fiberglass and bondo work.
That sucks! That rear quarter looks very similar to mine after being a victim of a hit and run last month on my way home from work just after midnight one exit from my house. I took off after the guy on the back roads off the interstate but he got away. Fortunately he did me the favor of losing control of his car and rolling it. He was caught not but 10 minutes after he hit me. He was under the influence, on probation, and had a suspended liscense. He is still sitting in jail. Fortunately there he was insured. I will be putting my DB2 in the shop soon.
