my trailing arm bushings need to be changed should i go with oem or urathan ones will it change the ride of the car thanks
Here’s a few suggestions, SEARCHED, “trailing arm bushings” (your title).
http://forums.g2ic.com/showthread.php?211647-Rear-trailing-arm-bushing-Fitment-Suggestions&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?183654-OEM-Trailing-Arm-Bushings-vs-Aftermarket&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?191679-Replacing-rear-trailing-arm-bushing&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?184799-Trailing-arm-bushing-repair&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?177693-rear-trailing-arm-spherical-bearings&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?177330-RTA-bushing-part-confusion&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?173547-Is-there-a-Rear-Trailing-Arm-Bushing-Extractor-tool-for-DAs&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?160965-prothane-trailing-arm-bushings-istalled&highlight=trailing+arm+bushings
http://forums.g2ic.com/showthread.php?143640-Replacing-Trailing-arm-bushing&highlight=trailing+arm+bushings
thanks for ur help
