tranny fluid fill hole ?
does it have a black cap over it??? its different than the hydro tranny i had before
its right above the drain hole
u loosen it with your 3/8 wrench without a socket
You loosen the drain wit out a socket the fill is a 17mm be sure to take of the fill before the drain just in case u have problems getting the top one off u dont got problems like i did when i had a drained tranny with no way to refill it.
oops i knew it was one or the other
i have been corrected
so it doesnt fill from the top???
The bottom drains and the top one fills. What he means is loosen the fill (top one) 1st so you KNOW you can get it out. Then open and drain with the bottom one. Otherwise you gots no juice and no way of getting any in.
What you are referring to is the vent hole - leave it alone.
Raise the car level (not just the front), and you’ll have access to the bolts that the others are referring to and will be able to fill the tranny with fluid to the proper level.
i got it…its like my old prelude tranny…should have realized it when the tranny was out…oh well
