it looks like it is leaking right around the seal that is next to the drain plug on the transmission, i tried some Lucas transmission leak stuff but no luck, could i have it filled to much or just need to replace that gasket in there?
Are you talking about the big gasket the goes around the axle?? If it is leaking from there then you should definately get that replaced.
Later,
BR
