tranny-motor-clutch compatability
do any of the 94 and up models that have the b18b1 motor have cable tranny/clutch or are they hydro ??
my prob is i have a cable tranny now that is on a 92 b18a1, that has a whole clutch package (flywheel and all that)
my car got totalled, and i am prob getting a 91 teg with a 95 b18b1 motor and tranny.
so if it does have cable, will i just be able to swap clutch and flywheel and stuff or should i swap tranny completely over from my b18a1 to the b18b1 ??
if it has hydro then nothing will swap the clutch or the tranny right ? so in this case i should swap my complete motor and tranny over.
please SEARCH. your questions have been asked before and have been answered.
not only that, the questions you are asking are basically the same as in your other thread, which have been answered. if you have any further questions, use the thread you have already created that covers what you are asking here.
http://www.g2ic.com/forums/showthread.php?t=130514
ALL 94+ tranny’s are hydraulic. swapping internals of a 94+ or swapping the tranny itself has been covered. search.
and for future threads you plan on making. please use a more detailed title for your threads. one word titles as you have used in previous says nothing in detail/specfic about your thread. you will get more replies/views if the thread title is more detailed about your problem. this is discussed in the forum faq:
http://www.g2ic.com/forums/announcement.php?f=29&announcementid=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
