Tranny or clutch?
When i first bought my G2teg the previous owner said that he was having a problem throwing the car into any of the gears, and i asked him what would be the problem and he told me that the clutch was bad on the car. I then went like 2 days after buying the car and bought a aftermarket clutch and had it installed. The car was running fine, problem fixed i thought, but like 1 or 2 months later the car started with the problem which was that the car doesnt like to take 3rd gear without a hassle. To me its the tranny but then again when my clutch was installed the car was fine for a while…What can it be and what can i do?
You say it’s hard to get into 3rd – is that just at high RPM’s? Does it grind? If so, it’d probably be the synchronizer in the tranny.
Otherwise, I’d make sure your clutch freeplay is adjusted correctly and see if that makes a difference.
good luck
