tranny swap (stuck, need help!)
hey guys am changing tranny from my old DA to another one a got a few months ago…am stuck right now because my axle nut wont turn loose…can i still remove remove the tranny without taking the axles off first or is there a DA trick…any tranny how to’s would help…i just wanna get my DA on the road sum1 help ppllzzz…
soak it in wd40 or whatever you use, put your socket on a breakerbar or ratchet and attach the longest pipe you can find the longer it is, the less effort it will be. pry on it and it should unscrew eventually. if you don’t want to take the axle off, you can take the steering knuckle off of the top balljoint, swaybar, and steering rack ball joint. from there, you can pull the axle out of the tranny.
first , did you use pb blaster and breaker bar?
when you can move the hub freely , then you can slide the axles out from tranny, i think if you take off the lca, steering rod and whatever holding the hub except uca, i crashed my car, thats how i got the motor and tranny out, i didnt lose the axle nuts
but i dont know if you toe would be off or not, i hope this helps
good luck
try taking it to a tire shop they will loosen it up with the impact gun for like 10 bucks just take the socket thats what i did. if not just remove the uper and lower ball joints and your tie rod ends and pull everything off (spindle) the axle should slip out enough for the tranny to go down.
