I have a b17a longblock sitting in my garage, as well as an engine stand that i just bought. I need to know what size bolts i need to buy to mount the engine to the stand.
I do just bolt the stand to where the tranny bolts to the block right? Anyone know the thread info and what not about these bolts so i can go buy them?
They are 12x1.25mm. You will need them just long enough to go through your engine stand, and leave at least and inch to thread into your engine block. Best of luck.
thanks dan, i’ll have to go look for some tomorrow.
oh, when you say “12x1.25mm” i’m not quite sure exactly what you mean (sorry for being ignorant). I’m just not sure what dimensions this is describing. thanks.
The size of the bolt is 12mm in diameter. The thread pitch is 1.25mm. Then you get whatever length you need. Places that carry the bolt will know exactly what you mean. Best of luck.
