Tranny
I have a 90 GS and this is the secind time this problem has happened to me. My car is an auto(yes i know that is the first problem). All the gears work but once the car warms up it wount go into any gear. It will show that it is in gear and as long as i keep it in one gear and dont change its fine. But once i change gears it wount go it acts like it is in neutral. The first time this happened to me i swapped trannys. I hope that there is sumthing other than the tranny this time do any of u know what might be wrong or what to check for or have had the same probly and what u did? Any info will be much apperaciated. Thanks for your time!:confused:
Did you change the fluid?
I havent changed it but i have checked it and it looks fine.
Well i’m certainly no auto-tranny expert, but the same thing happened to me with the 1 auto car I did own… and when they changed the tranny fluid and filter, it engaged fine. Obviously it could be more serious problems though, and I wouldn’t wait to have it checked out.
thanks i’ll go get sum tranny fluid and filter tommrow and see if that is the problem.:smiley:
