Transmission Fill Location URGENT!
Hey - I just replaced my clutch and had to drain my tranny. Now I’m unsure as to where the exact filler plug is located on the tranny housing to fill the thing back up. If someone could tell me exactly where its at - that’d be great. And please don’t say look in the manual, I don’t have access to one at the moment. Please help. I know this is in the wrong forum, but it’ll get more replies here. Thanks!
the higher plug on the right hand side of the diff. i think. if you look near where the passenger side axle goes in i think it was right next to their. you can use a half in. extension to get it out and i just filled mine with 10w40 till it reached the hole. good luck
Should be a 3/8 instead of 1/2". When you refill it, for the sake of your trans., use Honda MTF! Also, if it’s too difficult to get to that plug you can also remove the speed sensor and fill, but be careful how much you put in.
