I drained my trans fluid to replace it and found that the fill port will not budge and am afraid to strip it anymore than it already is, I heard you could use the speed sensor but wasn’t sure.
I had the same thing happen to me, I filled mine through where the axle pops in, not sure if thats a good way to do it i just stuck a rag in the hole with the funnel and filled it, my axles so happened to be out at that point (needed replacing) so that option might not be good for you if you dont have it out already or dont plan to take it out
You can refill it through the vent tube. Use a funnel and pour slowly.
Where is the vent?
Top of the trans in front just behind the the lifting bracket. It has a black rubber cap on it.
Doing it through the vent runs the risk of over servicing it though. Actually I’m not sure how you would be able to tell if it’s properly filled without the fill plug coming out. Have you tried putting a bit of heat to it?
No I’m having my neighbor come over and try to get it, he’s worked on a lot of Hondas in the past so hopefully he’ll figure something out
Did you try a cheater bar?
