I’m at a seller’s place this very moment, and I need to figure this out before I buy this car. I have done lots of searching and I understand the basics on how to do this, however something isn’t adding up.
I have the list of gear ratios, and I know that you have to count the revolutions of the input shaft versus the output shaft, but this car is complete minus the motor, and the transmission is attached to the axles. So I am counting the revolution of the input shaft compared to the revolution of the tires. The numbers I am getting are exactly half of what they should be for a GSR transmission, but I don’t understand why this is happening.
Example, in first gear, the input shaft turns about 7.3 (I’m eyeballing) times to the tire spinning once.
GSR ratio is 3.307 times final drive of 4.4 equals 14.55 revolutions. Double what I am seeing.
An LS transmission would give me 13.78 revolutions.
All 5 gears are giving me exactly half the number I’m expecting to see for a GSR. What am I missing?!
