i got my car switched to a 5 speed(2 months ago) but i was driveing today and i seen smoke comeing from under the car. so i was like wtf so i looked and there was transmission fluid slowly leeking out .so i drive home and its still leeking out slowly whats up with that???
The only way you can find out where it’s comin from is to get the front of the car up on stands and find out where it’s leaking.
The seal for the syncros may be bad…remove the tranny and reseal it…also, make sure that the bolts that that hold together the syncros cover are tight
make sure your fill and drain bolts are tight… prolly the most common leakage is from the axle seals…
