Transmission Questions??
Hi guys, I was wondering what I have in my car as far as acceleration/reliability, Etc. Currently I have a A1 transmission, but I have been doing research and this is the best reference I can find here: http://lonewolf-online.net/cars/honda/transmission_guide/
My question is how do you read this chart?? If I were to quickly look at it I would think the A1 transmission is one of the lower geared transmissions due to the lower numbers in each gear compared to others. I could be absolutely wrong and it may be the other way around, but just looking for input. I see its classified in the same category as the USDM YS1 from the b16 that everyone says are low geared. Do I in fact have the low geared transmission?? By the way mine is a cable transmission from a 91 Integra.
I see people looking, but no one ir replying.
:bawl: …and I cannot find 1 thing online about the A1 transmission. I see all types of stuff of the 3 different versions of the YS1, but absolutely nothing on the A1. :bawl:
So, if I recollect correctly, over the last couple months there has been plenty of discussion about trans and gearing. I suppose it has to do with if you want to live in the red alert 4-8K rpm range or just rip it from 3-5K. Different needs for each of these and having to live with the other by default. By the way, I sent you a coupon for a box of snot rags.
Really though, I see all types of info on the YS1 transmissions, but absolutely nothing on an A1 transmission and I have even googled it!! For now I will assume its long geared seeing as the 1 article I found on it classifies it in the same category as the YS1. I will assume long geared & NON-JDM, but I do have a lightened flywheel though so that should help me pull away from certain vehicles I guess. At a light today I was next to an RSX, and when it turned green we were traveling the same exact speed, but I noticed I was able to shift into second way earlier then she did. Mind you we were not racing! I am still babying my 2 day old setup to help break it in and “she” did pass me…and had the nerve to rev her engine driving by…LOL :rockon:
http://hondaswap.com/reference-materials/honda-transmission-specs-29132/
if you are reffering to the b18a1 motor? the code for the transmission that comes with that motor orignally is the long geared ys1 it sucks I have a xsi swap which came with the extremely short geared ys1 awesome! I will tell you that you will see a noticable difference if you switch to that trans at least a 1/2 second in 1/4 mile
yeah, I figured that. As everyone says with the gas prices the way they are now i’m ok with the long geared tranny. Maybe in a year or so i’ll switch, or if I stumble upon a deal I can hook myself up.
I did a little reasearch on here and a few people have said that the A1 transmission is slow on the bottom end, but overall produces faster times in the quarter mile. I would also think if you run out of gearing on the top end you would have to even out with a short geared tranny where as the the long geared tranny would still be building torque. Maybe those people were referring to turbo applications though. :werd:
A1 is you block…not your tranny
What block?? I have a b18c engine…the transmission has and A1 label on the front of the bell housing.
i assumed you had a b18a…
i did some research (took me 2 seconds on google BTW)
you have an LS tranny…
Is there any transmission that can be put on a B18C1 that has six speeds?
