Well my transmission seal is leaking at shift linkage. Ive ordered another seal and need to replace it. I know to drain the transmission fluid, remove the boot, and bitch pin. I cant seem to find any info if this seal comes out with a screw driver. Can I just pop it out from under the car? screw driver to pop it out?
it pops out. just pull the bitch pin and remove the boot.
You may want to replace the boot as well.
