was wondering if there were any other honda/acura transmissions that can fit into a 1990 integra? it is a auto but i wanted to know if there was a shorter geared tranny ?
i know " i serched and found a lil’ bit of info " i know it has to be a b-series tranny and must be cable to make it easy. so if someone is running a different transmission in there ride right now can you tell me what the process was or if yall know of a website to read a how-to that would help thanks.
Any B-series transmission will fit, but later models are hydraulic. So you would need a conversion kit! The 92-93 GS-R (YS1) is a great option, because the gear ratios are close to the Type-R’s and all of the motor mounts match up! However, I do believe it is hydraulic!
Hope this helps you!
Im pretty sure the 92-93 gsr tranny are cable. You can use the b16 cable trannies too and they are shorter geared as well.
but can i use those trannies on a AUTO integra? i thought 5spd trans only work with 5spd cars? also i heard of people using a accord transmission for better gas mileage. what accord would this be out of? the only reason i asked is because i wanted to know if there is a transmission that can be put in a AUTO integra that has short gears.
seeing as a 5spd has a upper hand on gear shifting i thought it would be cool to know if this was possible. and i know i can do auto to 5spd swap but rather not. thanks again guys
Yes! Try the search bar at the top of the page!
This might be what you are looking for!
http://forums.g2ic.com/showthread.php?40496-automatic-to-manual-swap-(auto-5spd-conversion-writeup)&highlight=Auto
