ok, im not very smart when it comes to trannys i just know the cost a lot. jk i know a little but i was wondering if it would benefit me to rebuild my 91 tranny with a 98spec itr lsd and 1st gear or should i just look for a newer tranny, i know that the 90-91 s1 trannys are not very favorable but im stuck with 2. i pulled the drive train out of a trashed 91 and i have 90 for a dd. should i just find a 92-up cable or what?
You cannot rebuild your 91 transmission with 92+ gears.
If you buy a cable 92-93 (JDM 91-92) transmission case, you can use 92+ gears and differentials if you use the corresponding countershaft.
[QUOTE=kNOwLedGe420;1864677]You cannot rebuild your 91 transmission with 92+ gears.
If you buy a cable 92-93 (JDM 91-92) transmission case, you can use 92+ gears and differentials if you use the corresponding countershaft.[/QUOTE]
so your saying if you want LSD, with a cable transmission the only way is to have a 92-93 casing… thanks buddy
