TRI-Y header???
i was wondering if anyone is using the tri-y header with out using a half rad and removing the a/c… i was about to purchase one until i saw my boys in a eg civic.
Yeah I will be using that header here at the end of the month. I was told to get it and yes I am running ac, and a full rad.
sounds good… can u post pics after installation?
Im running it right now with ac and oem radiator. Only thing you will need to do is notch the crossmemberfor install
dont have mine in but test fitted before pulling my engine. will fit just fine with stock radiator, fan, A/C, but you either have to notch the crossmember as mentioned, or get a traction bar for the extra clearance.
