Trouble installing seats on w-r brackets
Im about to install some aftermarket seats on some weapon-r seat brackets but there is only one tab upward.My aftermarket seats have holes on the sides for brackets.If I use the weapon-r brackets do I have to drill 4 holes on the bottom of the seats to bolt to the brackets?Seems like the seat brackets should have 4 tabs upward,2 on each side so I can bolt up the seats.
Hmm, yours are different than mine. Mine came with the standard upward hole distances, but instead of the flat side rails I have cylindrical bars, with tapped holes on each end for horizontal mounts on the front and back of the seat rails. The seats you are using, do they have sliding rails or not? Much easier to drill into stationary rails, you can use bigger bolts too :slight_smile:
darkintegra:
what seats specifically are you trying to put in? i have the weapon-r brackets mounted up to sparco’s, however, they (seats) use four holes on the underside of the seat. not the sides. it appears you need different brackets.
how well do the weapon r brackets bolt to the floor of the integra? do all the holes line up with the oem ones on the floor, cause i just got some momo seats and dont wanna waste 100 bucks to get more brackets that dont fit :bang:
well, they work. it only took a buddy of mine leaning on one corner to get it to line up. the driver side lined up perfectly. the seats themselves do sit a little high, but i think that is more a function of the seat. i dont think you could get any lower brackets.
thanks man i been checkin this everyday to see if those barakets were worth getting or not! thanks for the reply… sorry if i thread jacked :angel:
same here, mine look different
Hmm yeah, same bracket as me da9leo. For those that don’t have the cylindrical style side bars on their brackets, what is the part# you have on them? … :read:
