trunk help
i pulled out my spoiler and there was a big rust hole. can somebody please give me tips on what to do besides buying a new trunk. i already purchased one and it was to big. everybody says that the 90-93 trunks are the same but it didn’t work.
Well there is a difference in trunk lid sizes/shape between 2dr. and 4dr.
yes i know that. i have a 2 door so i bought a 2 door trunk. it didn’t fit.
Then whatever trunk lid you got was the wrong year and/or car as all 90-93 2dr trunk lids are the same size and shape.
doesn’t make sense because you said possibly wrong year but later you said its all the same size and shape. i have a 1991 and bought a 1992 trunk lid. i don’t think it should be any difference right?
Um…wrong year as meaning 94 and up or 88-89. :think:
Trunk or hatch? I’m lost.
no i know the new one is from a da9 not anything else. it fits on but it sticks out a lot. i tried adjusting it and everything but no matter what, the trunk still pops out. anyways back to the topic. how can i save this trunk?! i was thinking about cutting off that entire rust spot and then putting bondo over it. what do you guys think?
Clean, then sand, and maybe some bondo, finaly paint to match color.
^can you please be more detailed. its rust and i dont know if i have to cut off the rust or can i just bondo on top of it?
completely cut out all the rust, shape of a square or so. if you just sand it down it will come back eventually. weld in a clean peice of sheet metal from the bottom then cover it up on top with bondo. might need some glazing putty ontop of the bondo if it gets some air bubbles or holes. sand, primer and paint. done. That looks pretty bad though, I would just buy another hatch. all 90-93 2 door integra hatches are the same.
im 100% sure it is a da9 trunk but it doesnt fit. it doesnt even close unless i apply pressure to it. for some reason the new one i bought stuck out a lot. so i just put back the original rusted one. thanks a lot on the tip. i will see if i can do it that way.
well even tho how old this thread is 90-91 trunks are different then 92-93 the tails angle in more on the newer ones
That is for a 4dr. and this thread is about 2dr.
Your only a year late with info we already know.
