turn signal is going crazy
so when i put my turn signal on left or right they both come on but only in the front what does that mean? wires crossed maybe?
Only the front signal comes on and the blinker goes fast?
You’ve got a bulb out my friend.
Your going to have to be more clear on what is happening.
You say, "but only in the front ", does that mean only the front signal lights work, not the back ones?
Does it mean that both the left and right signal lights come on only on the front and the rear ones work normally?
If so, are you talking about the front side markers or the signal lights in the “bumper”.
If you are talking about the front side markers and they are the only ones that both left and right sides come on when you signal in either direction, then the problem is the ICU, the ICU controls the front side markers, the front and rear signal lights are controled directly by the signal light switch, [or hazard switch if on].94
