Turn signal issues
So i recently got my 92 da project running and now it went from my project to my only car and some issues need to be taken care of asap one of these issues is the fact that my turn signals dont turn on the lights on the cluster dont even light up but yet my hazards work perfectly fine any help?
Check fuses.
If you took anything apart, make sure it’s all plugged and no wires are shorted.
did that checked every single one in the whole car
The signal light fuse is fuse 1 - 10A (91-93) fuse 23 - 10A (90), [hot in run and start in under dash fuse box.
Replace this fuse with a new or known working fuse even if it looks good.
If that does not get the signal lights working the problem is most likely the hazard lights switch, signal light switch or wiring.
You will need to pull the hazard switch and test some wiring. 94
