[QUOTE=fcm;2097890]MM&Y of car?
So I understand…
After the “mod” the fog lights work properly, [do low beams need to be on or are the fogs rewired]?
When you turn on the park/head lights your rear right signal light comes on, does it blink or is it on solid, do all the park, [tail] lights work properly?
The front side markers are controlled by the ICU, blink on as signal or hazards, turn on as park lights and blink off as signal or hazard lights if park/head lights are on, if there is any problem there, it is most likely the ICU.
Do they work properly otherwise, only the left blinks when left signal is turned on?
Unless the front bumper lights have been rewired they should be signal/hazard lights only, correct?
What does “they’re just permanently on” mean exactly, both on solid when signalling left or right, on with park/head lights, or what?
Without more info all I can suggest is you recheck the head light assembly install, make sure you have not “pinched off” part of the wiring harness. 94[/QUOTE]
ok sorry some of that was unclear.
my bumper lgihts are “permanently on” meaning they stay on with my park lights, and they don’t blink whatsoever.
& by fog lights working, i mean the bulbs light, factory setting: headlights on first.
but here’s the problem:
when my park/head lights are on, everything works fine (including corners)
but when my lights are off, my right turn signal makes my corner lights both blink. rear turn signals are working properly at all times.
i guess i can run park lights during the day so my signals work right? lol what’s the legality of doing that
