I just installed a replacement ignition and ignition switch and now my turn signals aren’t working. No clicker noise, or lights on the outside or on my cluster. I checked my fuse under the steering column and it’s good, and the wiring that plugs into the switch looks good and plugged in. Help?
[QUOTE=justharoble;2258111]I just installed a replacement ignition and ignition switch and now my turn signals aren’t working. No clicker noise, or lights on the outside or on my cluster. I checked my fuse under the steering column and it’s good, and the wiring that plugs into the switch looks good and plugged in. Help?[/QUOTE] Do your hazard lights work?
Signal light fuse is fuse 1, [91-93] and fuse 23, [90] 10A, [hot in run and start] in under dash fuse box.
How are you checking the fuse?
You can not tell if a fuse is bad just by looking at it, unless it blows at the “window”, use a 12V test light with the fuse still plugged in and test both test tips, [with ign. switch on].
If the fuse is good you will need to pull the hazard switch and test for power on the yellow/red, [may just be yellow] lead, [signal light power input to the hazard switch]. 94
