So I noticed an unusual glitch in my turn signals. It only happens in the front turn signals. When signaling left, it will work correctly and the left upper and lower light will signal a left turn ,but ,when signaling right, the left upper signals and the lower right signals. The upper right doesn’t signal. Has anyone experienced that problem before? If so, what did you do to solve it? I’m thinking of just replacing my ICU but was wondering if there is anything else I should check.
yea ive had that too…when i signaled left both bumper and corner light on the left worked fine but the corner light on the right was blinking too…i dont know the source of the issue but i tried to show some freinds this trippy glitch and it “fixed” itself…i dont know why but it just went away for me
Multi Fuction switch, A.K.A. the thing hanging off you steering colom, is the normal cause of such problem!
