Took the dash out and changed out the dash harness because the radio harness had been destroyed and now the turn signals don’t work but the 4 way flashers do. Tried a new switch and the fuse and that didn’t work either. Any ideas guys? Thanks.
does it make the clicking noise when the signal is applied?
I mean the switch clicks but no you don’t hear the clicking as if the light was blinking
probably flasher relay. maybe you forgot to plug it back in?
If the hazard lights work everything after the hazard switch is good,including the “flasher”, [hazard/signal light relay].
Op you need to pull the hazard switch and see if you are getting signal light power into and out of the hazard switch. 94
^^i thought these had a separate relay for the hazards. no?
Ya that’s what I thought that the flasher might have something to do with it but even when I changed the switch with another one from a working car it had no affect. From what I’ve gone over I’m getting power everywhere I need it but there just not coming on like they supposed too. When taking it apart to change the dash harness I kind tugged on the harness a little hard while it was still plugged into the switch could that have pulled something lose somewhere? And if so why do I still appear to get power everywhere?
As a safety feature, every hazard light is hard-wired to a constant hot, while your signal lights only work when the key is in the ACC and up. They are on separate circuits.
Do you have a wiring manual/diagrams? I could do more when I get back to work next week and can locate wiring diagrams via AllData.
Of course, if you’re in my area, you don’t need turn signals! (or so some people think…)
you might have accidentally disconnected the small lil wire that goes on the positive clamp with the fuse… I took out my tranny then put it back 3 weeks later and noticed my turn signals didnt work. I check fuses and the battery. It wasnt until i took off the read cover on the positive clamp that i noticed something was unpluged. Found the cable, pluged it and my hazards workd.
if all else fails your gonna have to get a repair manual from autozone/shop and follow the electrical diagram on the last chapters.
i just did a auto to manual swap, so i turn my 90 rs into a 93 5 speed and now i only have running lights on the right side onl, no hazards or turn signals and ideas what i could check?
i’m on the road to putting my DB1 on the road for a 2nd time this year…prior to the trans going out this time, my signal lights stopped working and hazzard lights…when i activate them, they just stay illuminated and you dont hear the clicking as if it’s flashing but it’s not. they just stay lit.
any ideas?
bump
guess cant get help on these forums any longer
for anyone else looking for solution and may stumble across this, my signals started working again randomly for not apparent reason…still dont know the issue
