turn signals
wussup
im having problems with my turn signals
and the problem is they dont work
its not the bulbs because the hazard lights work
i put a test light to the plugs behind the steering wheel and theyre good
but there is no power going to the fuse connection
does anyone have any experience with this?
if so please enlighten me
thanks in advance
Have you checked the blinker relay?? That could be the problem.
I havent done one in a teg yet or I would help out more. It should be under the driver side dash panel though, somewhere in there.
Later,
BR
thanks for replying br
i was thinking the same thing but have not been able to locate it
does anyone know what it looks like or have a pic of it
thanks
mabey a wire went bad…or if you have moded you lights at all sometimes cutting and splicing can cause weird problems like that but other than that just check the fuses and if its not that then i don’t know what it is…do the blinkers by the guages blink?
hope it helps…
later,
Dan:p
yes i did mod my lights
i turned the jdm yellow fogs into my turn signals
but thats not the problem because my hazard lights work
the turn signals in the gauge cluster only work when i turn on the hazard lights
you probably burnt out your flasher relay or turn signal wires. i don’t think your suppose to have turn signals that have a wattage of anything higher than 21 watts. so wiring up your fog lights as your turn signals might have been too much wattage for the turn signal cicuits to handle.
spikeymike-
if that were so would i still have power going to the fuse?
because right now i dont
i located the relay (i think) all i need to do now is find another one that i know is good
which on is the relay the black box with mitsuba on it or the brown one?
thanks
nope, no power going to the fuse. the blinker relay is a black rectangle like black box with three connectors on it.
