turning noises
when i turn right, it makes a clicking noise while im turning but not when i turn left, my axles are both brand new with new boots on them, what else could this be, bad suspension, controls arms(which i have the adjustable ones) or anything else like that.
Clicking or Clunking?
Lots of clicking or just one or two clunks? Explain in more depth please :wink:
4 or 5 clicks depending on how long my wheel is turned. it is the same noise when i stop and my front kind of goes down a little bit you know, it makes kind of a pop noise also. i push down on the front of the car and i can get it to make the noise also.
Yea i got the same problem, new axles. I think i’m gonna try reinstallin the drivers side and see if that does anything. If not then i’ll wait until something bad happens then i’ll know…
could be your suspension. I know my g/f’s older Accord did this like every 12 months… turned out to be a bushing or something along those lines in the suspension setup. Can’t recall exactly. If you can get it to make the noise by pushing down on the front, and it sounds like a creaking-type noise, it’s likely suspension.
~Eric
i will look into all those options this week sometime. thanks for helping
