Turning Signal blinker
For some reason my right side turning blinker ,is blinking faster then the other side. I check the bulbs and they are fine. Do you guys know what the problem may be?
could be wrong bulb size, sometimes a different number bulb will get used, it will plug in fine, look fine, and work just blink faster
[QUOTE=bryan24207;2279438]could be wrong bulb size, sometimes a different number bulb will get used, it will plug in fine, look fine, and work just blink faster[/QUOTE] really? i had this car for a while and this time is the first time it has had a problem. Hmmm do you thing if one of the other bulbs burnt out would it cause issue of blinking faster.
yea, i had one of the small ones in my tail light go out, was lit when running lights on, but when blinker would come on they would just blink fast…confused me
[QUOTE=bryan24207;2279441]yea, i had one of the small ones in my tail light go out, was lit when running lights on, but when blinker would come on they would just blink fast…confused me[/QUOTE]Solved the problem, My front turning signal was not fasten. It was inside, so the bulb was just rolling in the housing.
