Turning signals won't work
I currently just did a wire tuck I turned the car on lights on everything is working except the turn signals front back nor the inside the hazards won’t work neither I’m guessing that even if I wired the front turn signal wrong the back an the inside would still work correct? I checked fuses they were all ok does any one have any ideas why it could be possibly
Power for both signal lights and hazard lights go through the hazard switch before it gets to the signal light/hazard relay, after that all wiring is common.
Start by pulling the hazard switch out and checking for the two powers, hazard is hot at all times, signal is hot when ign. switch is on. 94
Thank you so much
