Type R Fuel Pipe
I am running a Type R intake manifold with a jimmy-rigged fuel pipe. In order to make it look stock I need to purchase a 92-93 Integra GSR fuel pipe, but unfortunately they are discontinued. Is there an alternative? Is it possible to use a Type R fuel pipe?
Why is it ‘jimmy rigged’? What fuel rail are you using?
I am using a Del Sol fuel rail and it looks very sleek, however they’re discontinued.
The ITR and '96+ GS-R share the same part number for the fuel rail: 16620-P72-010
They are still listed as current/available parts, however the cost is $200+.
I’m just curious as to what you’re currently using… I would ‘think’ a non-vtec b-series fuel rail would work fine also…
I’d just find a (in good shape) used fuel rail if it will have better fitment, bad fitment can cause dangerous conditions.
edit
A '99-00 Civic Si fuel fail would fit also, and it’s a bit cheaper, if you’re wanting something OEM. And it looks better IMO.
Part#: 16620-P2T-A00
Link: http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry2=2000&catcgry3=2DR+SI&catcgry4=KA5MT&catcgry5=INTAKE+MANIFOLD+(DOHC+VTEC)
I am using an AEM fuel rail. Stock fuel pipe cut on one end clamped around a nippled banjo end that is connected to the fuel rail. Does that make sense?
Ohh yeah… I’m not completely sure on that one then.
