TYPE R Manifold
What’s good everyone what’s the small line on the type r manifold hook up to? on the right side should I just plug it up and not worry where it should hook up to.
your description of this small line is so vivid…
take a picture
There are a couple versions of the ITR manifold, which may or may not be a factor in the answer to your question. Here’s a pic of mine:
Project 896_101709_016 by C o l i n, on Flickr
The small nipple on the front of the manifold connects to the fuel pressure regulator. (In case mine looks different feom yours its because I added a nipple to the rear which is hooked up to the purge control solenoid valve. On the ITR this nipple is larger and on the left side, not right - I removed that one and blocked it off.)
