Type R Shift-linkage work on our Cars?
Hi guys. I did search already.
Question is, “Would a Type R Shift-linkage fit out DA’s/DB2’s?”
I have a Type R tranny in my DA. and i now have the option of slapping on the Type R shift linkage.
any input.
THANKS.
Didn’t search hard enough.
http://www.g2ic.com/forums/showthread.php?t=148812&highlight=itr+shift+linkage
http://www.g2ic.com/forums/showthread.php?t=190177&highlight=itr+shift+linkage
http://www.g2ic.com/forums/showthread.php?t=177320&highlight=itr+shift+linkage
http://www.g2ic.com/forums/showthread.php?t=84791&highlight=itr+shift+linkage
Yes. It works. You’ll have to pick up a Type R/DC shifter though as well or modify the setup to work with your shifter.
-nino
damn,. sorry spiky mike. Commander. your right.
thanks anywho. and thank you NINO
[QUOTE=Nino;2122038]Yes. It works. You’ll have to pick up a Type R/DC shifter though as well or modify the setup to work with your shifter.
-nino[/QUOTE]
this also goes for DC STS as well right?
all b-series shifters should work… only difference is single vs dual bend so its pure preference which one you use
thank you sir
