so would running an aftermarket traction bar such as the one from Full Race allow you to use the EF camber arms? given that then the caster would be adjustable?
Is this about normal clearance with the Skunk 2 kit?
Yes you can, but it will put alot of strain on the lower ball joint and LCA bushings as you will be forcing the lower control arm to be pushed backwards at an angle it was not designed to handle. phatcardesignz actually tried doing this on his setup. His caster was so extreme with the EF camber arms that he could not correct it with the traction bar. Of course his setup is extremely low and using the skunk2 arms. You are unlikely to run into this situation unless you are slammed like him, but avoid Skunk2 EF arms if possible. http://forums.g2ic.com/showthread.php?178392-***LONG-AWAITED...DA-Skunk2-front-camber-kit-install***&p=1930063&viewfull=1#post1930063
