Where does the outlet on the oppsite side of the coolant bleed bolt connect to? The Helms manual does not help me, I cannot see it in the pictures. Does anyone know what I’m talking about and have pictures?
you mean the bleed bolt on the water neck?
it does not connect to anything it jus screws into the water neck.
loosen it a few turns and when the coolant dribbles out of it, the coolant level is full. tighten it up and off ya go.
HTH.
I just put my engine back together. I had sent the water neck away with my head. There is a nipple on the bottom, that I dont see where it goes. It is on the opposite side of the blees bolt. Does anyone know?
Anyone with info?
