Urgent need help with brakes
so im trying to take my rotor off and it wont budge. any ideas to get the middle part to loosen?
hit it. tap it with a rubber hammer or a piece of wood all around. pull pull pull. been there time after time.
Brake help
Well first you have to remove the screws holding the rotor to the hub and then it should just about fall off. If not then use the hammer.
^^ and also,tap the driver with a hammer as you spin it so you don’t strip the head.
ya i finally got it…it was so coroded I don’t think the person before me believed in changing brakes.
