using abs da trailing arms with non abs da integra
As the title states. Is it safe to run a abs rear trailing arm that came off a da integra on a non abs da integra? Will there be any problem? I looked it up and couldnt find much. Thanks.
No harm. They’re basically the same except for the hub which is different which has a part that the ABS sensor “looks” at to determine wheel speed. Technically there are probably some other small differences but they should only relate to accommodating the ABS stuff.
