vac. lines not right
Ok so im doing a obd1 b16a swap into my 90 teg. I gkt everything done but it wont stay idling. I am boosted using hondst s300. I pulled this motor when it was running strong no problems what so ever out of a del sol and swaped it into this da. Im confused on the vac line routing. I beleive i have a obd0 IM as my map sensor is not mounted on the manifold/tb. I left my old map sensor o the del sol and car is long gone. I just bought a used 3bar from a friend which is what i left on the del sol.
I have as followed. Line going from fpr to manifold(this was like this on the del sol with no problems)
Line going from map sensor to tb. Now i have one more port on tb. And dont know what its for.
Car will start up and idle. But idles rough and if i tap the gas to bump the rpms up. It either bogs down or dies co pletely.
Im lost as i need this car done by frieday. Im pretty sure i have all the wiring right.
A local guy told me i dont need the regulator valve hooked up or the other one next to it on the same bracket as the map sensor. Soo i did not hook thkse up. I do not have the char ol canister either as i didnt have it on the del sol.
My setup is as follows.
Obd1 b16a
Rewire obd conversion harmess along with vtec sub harness and §§§§§ conversion
Walbro 255
Turbonetics 50 trim
Raptor bov
Evolution wg
Emusa front mount
Rc440 injectors.
I am just lost here. I cannot find a vac line diagram to go by as they all have like ten diff lines and i only have like 4
Some one pleassee help
did you try messing with the ide adjust screw?
check to make sure that map sensor is good and working properly. post up the vacuum diagrams you are trying to use. even if the routing is defferent, the purpose is always the same. if that makes sense…
make sure all your couplers are tight and you dont have any leaks or open nipples anywhere…
what regulator valve are you talking about and post a picture of the extra spot on the tb that youre not sure of. with issuse like this, videos and pictures will get you help, not long and confusing descriptions…
Ok. Well i vot it running way better. I swore the del sol was tuned on a gm 3bar but i forgot what i had in there. I ended up cslling the old tuner and he said i had it tuned on the stock map. So i put the stock map from the integra on and i can drive it now. But it cuts out at 4k it doesnt break up or spit and sputter it just cuts out with lose of power but car does NOT shut off i just have to let off gas and step back on it. It happens between 4-4500k. I am using the stock fpr as well but thats how it was on fhe del sol. I am running a bramd new walbro with good fuel pressure. I checked plugs wires cap and rotor. The only thing i really changed is some of the ic piping to fit on the da , i am now running a 3" hood exit and not the 3" bwr downpipe. And i changed the wiring now using the da harness with appropriate rywire adapter.
