Vacuum Lines
Is it okay to replace the aluminum parts of the vacuum lines on the intake manifold? Mine are all tarnished and I think it would look better to remove them. If so, do the lines have to be the same length as the original lines, or can they be shorter?
Thanks,
Miles
[QUOTE=mrbloink;2171653]Is it okay to replace the aluminum parts of the vacuum lines on the intake manifold? Mine are all tarnished and I think it would look better to remove them. If so, do the lines have to be the same length as the original lines, or can they be shorter?
Thanks,
Miles[/QUOTE]
Yes. Length shouldn’t matter. Make sure you use vacuum tubing and not generic tubing which may collapse under vacuum.
When I had my Audi, I bought either this or this for my BPV. would either of these be okay?
EDIT:
I purchased the second one made by forge
[QUOTE=mrbloink;2171657]When I had my Audi, I bought either this or this for my BPV. would either of these be okay?
EDIT:
I purchased the second one made by forge[/QUOTE]
Those are more than adequate for the job.
