I just snapped one of the valve cover studs while torquing it down. It’s the one right next to the cam gears. Is it an easy fix? can i just replace the stud by screwing it out?
thanks
thanks
yes, you should be able to go to acura and pick one up. I believe it comes with a stud and the bolt if I’m not mistaken. Check out acuraautimotiveparts.net And fill in all your info. I checked it out and your looking at $6.00 from them, so probably around ten from your local dealer.
Good Luck!
Jeff
awsome thanks
if you want, U could go to a junk yard and pick one up. Thats what I did and it worked fine. I also have a couple of extra ones if you can come and pick it up, if you still need it. Good luck.
yah, well going to the junkyard will cost me about $10 worth of gas since it’s sorta far away, so I might as well walk to Honda and get some. I heard the studs are the same as B20 CRV engines and 88-91 Preludes?
