valve lash adjustment questions
Alright, so I made a few notes to guide me through the valve adjustment process- I’m not sure if the notes are right though (ie. the order to adjust the valves, etc)- so it’d be great if you guys can verify the info.
Also, I read in the Integra service manual (circa 1992?) that you had to re torque the crankshaft pulley bolt to 180N.m. How is that possible? aren’t you turning the crankshaft pulley bolt counterclockwise, instead of loosening the bolt? How would you tighten the bolt- by turning it clockwise? but are you not supposed to turn crankshaft pulley bolt clockwise?
