Valve Nut lost in the motor!
Well i lost it, it came apart and now i dunno where its at! I’ve taken down the oil pan nothing in there! where do you guys think it is at?
Why don’t you just turn on the car, and hope it flies out the exhaust? :smiley:
Shade
Hey, I noticed you’re from Columbus. Check out the meetings section, there’s a thread started for an Ohio meet.
Only place I can think, is that oil passage…
:frowning:
Fishing line and a magnet. Hope you have the right bait and their biting!
omg that sux man, i hope you find it with no troubles.
:frowning:
That is what I am thinking too… Give me a call if you need any more help with that, but I am pretty sure you will find it in one of the oil passages.
Ryan - I think that the torque wrench we used was seriously messed up and out of spec. That is the only reason that I can see those nuts loosening. Make sure to bring your craftsman one over after that nut pops up. Phil’s tools sketch me out…
Later,
BR
simliar thing happened to me, i just got a magnetic pen that extends, and started to go fishing. Good luck. (it costs like 2 bux at a hardware store.)
been there…****er disapeared :confused: drove that way for 10 000 kms, no problems (bought a new one though)
Hey, thnx for the tip, just posted there!
Rob
If you dropped the pan and it isn’t actually stuck in the pick up then it has to be in the oil passages…I’ve seen a lot of people try to do their own valves and this is one thing that happens quite often. I don’t think I’ve ever seen one make its way past the pick-up no matter how long its been in there. The telescoping magnet is definetly your best option…
J.
go driving on the freeway, and hope that sucker falls out and goes flying behind you’ll, you’ll know it’s come out when usee a car behind you swerve out of control from nut hitting there windshield:D j/k
I got the bolt. and did the valve adjustment!
Thanks for all the help boys!
BR- It wasn’t the torque tool it was actually the way we did it plus those cams are little AGGRESSIVE! I had to get Mike to come over with his SNAP on tool! its the bomb! my car runs better now but when i brake it shuts off! WEIRD! But thanks for all the help!
Originally posted by VietG
[B]I got the bolt. and did the valve adjustment!
BR- It wasn’t the torque tool it was actually the way we did it plus those cams are little AGGRESSIVE! I had to get Mike to come over with his SNAP on tool! its the bomb! my car runs better now but when i brake it shuts off! WEIRD! But thanks for all the help! [/B]
Good to hear that, Phil.
How do you mean that it was because of the way we did it?? Once the clearances are set and everything is torqued down, that is all there is to it…
Where did you find the nut?? Oil passage??
Later,
BR
I know it’s kinda old but yeah where did you find the nut VietG?
